Cannot add a PRO 5S 2K camera to my VMB4000 base station
Been trying for many hours but cannot get my new Pro 5S 2K camera to blink blue to scan the QR code. It blinks once when I insert the battery. I tried the sync button on the camera, but it never blinks amber, so the QR code does not appear to scan.
So frustrating.
I'm ready to return the 3 cameras to Best Buy before the 15 day return window ends.
I have a Netgear Mesh Router, Nighthawk MR60. I have tried to figure out to configure the router to only have a 2.4GHZ SSID so that the camera and ARLO Secure would use the 2.4, not the 5 GHZ SSID to connect. It is very confusing to me.
Any assistance would be greatly appreciated.
Have you tried holding the sync button down for ~15 seconds? The LED should flash amber by then.
Also, make sure you are choosing the Pro 5s camera when you add device.
Yes, it never blinks blue, so I eject the camera from the base and hold the sync button for much longer than 15 seconds many times. It never blinks amber no matter how many times I try.
So frustrating. Thanks for your reply. Wish I could figure it out and not return the 3 camera bundle to Best But
I think it has something to do with the Netgear Nighthawk Mesh router RM60.
Not sure how to configure it to only connect to the 2.4 Ghz sode. I have tried many things, but have not been successful. I even disconnected the 2 satellite units from the router. That didn't help.
Arlo tells me my problem is that I need to upgrade my plan to be able to add more than 1 camera
@tomdemott were you able to onboard the Pro 5S to the system?
only 1 of the 3 PRO 5S 2K got connected to the VMB 4000 base
ARLO Tech Support said 2 of the new camers are defective. I do not believe that!
@tomdemott what type of device are using to try to onboard? Is it a iPhone or Android?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
