HI,
I purchased several Arlo products to test out its' features. However, I simply cannot find the product in the Arlo Secure app's device addition page.
The product I purchased are as follows:
- Arlo Pro 5S 2K
- Arlo Video Doorbell 2nd Gen
- Arlo Essential Indoor Camera 2nd Gen
I'm located in Republic of Korea(South). I have tried VPN, US play store accounts, iOS accounts locales, but the app just would not show those products I purchased. Is there any way to try these products here?
Thank you.
- Arlo Pro 5S 2K
I suspect they aren't sold in Korea - which is why they aren't shown in the app.
If you can create a test account in the US (using a VPN terminating in the US), you should then be able to add the cameras to the test account. Note you only use the VPN to create the account. I think the payment method would also need to be US, so after the trial expires you might also need to add a US payment method.
Don't enter a home address when you set up the camera location. If you leave it out, you'll be able to set the timezone as desired. And a Korean address might also not work.
- Arlo Pro 5S 2K
Worked like a charm! Thank you so much for your input!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
