wondering if anyone can help.
just upgraded from the essential camera to the pro 5, the app updated to the newer version to support camera (i think)
tried connecting and it just times out when searching.
i’ve tried my iphone, my wife’s iphone, a pc, a laptop. i’ve tried creating a hotspot and nothing works, i’ve taken the camera back to bunnings and swapped thinking it was faulty. i created a guest login at 2.4ghz through Telstra and nothing works. the support team are hopeless and told me it will go to the next level but hear nothing back, so thought i would try here. any ideas would be appreciated.
never had a problem with previous essential cameras
Did you try a hard reset of the camera? (Hold down the sync button until the camera flashes amber).
yeah tried that too 👍
Ok.
After you get the chime from the camera, try checking your router's attached device list. See if that camera is shown there.
If it is not listed, then the camera wasn't able to join the wifi network.
If it is listed, then the issue is that the app isn't able to discover the camera for some reason. One easy step you can try in this case is to turn off mobile data on your phone before onboarding.
thanks Stephen, i’ll give that a go 👍
Hi Stephen, tried it and the camera doesn’t come up in the list of networks
finally got it to work, the only thing that was different as i tried mobile data off once before but i un highlighted the apple home setting in the arlo settings (through phone settings) whether that had anything to do with it or there’s a storm coming i don’t know haha, but thanks for your help
Great.
FWIW, onboarding is often much harder than it should be. Something Arlo really should fix.
yes absolutely! never had a problem until now but thanks for your help 👍
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
