How do I stop my camera from switching Wi-Fi from 2.4 to 5 or being connected to both?
There's not much you can do to prevent this.
Are you seeing the camera go off line (or perhaps seeing garbled recordings)?
Potentials options depend on your router features:
- Some routers let you create an iOT network that is only 2.4 ghz. If yours has this feature, you could use that with the cameras.
- Some routers let you set the power for each radio. If yours does that, you could try reducing the power on 2.4 ghz and see if you get a stable 5 ghz connection.
- Moving the camera closer to the router might also help.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
