App keeps searching for camera
I bought the 3 camera pack. Installed initially 1 and surprisingly it just connected to 5 Ghz . Now want to install the other 2 but it was asking for 2.4Ghz connection. Changed my phone WiFi connection to 2.4Ghz and tried so many times. After the chiming of camera it does not connect to the app. Meaning the app keeps saying searching for cameras but does not connect to the app. After blinking blue light 5_6 times it stops blinking also and the app says no cameras found.
Pls. Help
Maybe try the hardware reset next (pressing sync for about 15 seconds, until the camera LED starts to flash amber).
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
drained battery
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
Wifi connection
wind
Zones
