I have been trying for over a month and half to get some of my cameras to record after motion detection and initiate siren for a certain time period at night. During the day, I need them to go back to normal and only record for certain cameras, no siren.
I have talked to many techs and nothing has helped (upgrade app, delete automations, reinitate). It has been escalated and suggestions have been done but nothing helps. I am having to do initiate the automations on my own. This is not what I expected. If Arlo has a feature, it needs to work. This is very frustrating.
So the automations themselves work? They are just not kicking in when scheduled?
Can you post screenshots of the two automations?
unable to upload screenshots from my laptop. Automation schedules are working now, finally, turning on and off as I scheduled. 1) Issue now is that there is no recording when siren goes off. 2) I can see on feed the schedule/mode change, but the other night siren going off in one camera but no recording.3) really frustrated that level 2 is not calling me after talking to several tech reps.
The automations should only be changing the mode - no other actions.
What happens when you try to upload the screenshots?
I have escalated your case & someone from support will be reaching out to you as soon as possible.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
