I go to default mode settings and try to change the “record for a fixed length” to a shorter time and it’s no longer remembering the change. It keeps recording for 59 seconds. Motion sensitivity is likewise not changed when I try to decrease from High to medium. Is there something hidden that needs to be found to save these settings?
iPhone 14 with firmware 1.040.27.10-105-24777521
James, I checked routines and found that if I customize the recording duration there, it saves and I can shorten the length. Also can lower the motion sensitivity from there.
Just does not allow changes from the main Device Settings?
thanks!
Barry
Byedvob,
The settings should apply automatically for the default mode.
Are you using any custom configurations within the modes under routines?
thanks!
Barry
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
