@roundball wrote:
Yet your Pro5 Firmware and our Pro5s Firmware are not the same, they’re different.
Both have the same part number (VMC4060P) which I think is clear evidence that there is really only one camera model (just branded differently in some countries). FWIW, I always found the "s" in Pro 5s to be a bit odd, personally think they should just call it Pro 5 everywhere.
Sorting out differences in firmware is tricky because
- New firmware releases are done quietly (nearly silently)
- Some folks are on Field Trial software, others aren't.
- Arlo almost always uses a rolling release process, so it can take a long time for a new release to reach everyone.
- Firmware in Europe often lags behind other geographies (I think linked to the Verisure partnership).
@BrookeN for the sake of this audience could we get an update? What is happening with this known fault? What is the scope?
I'm confused: is there a problem with firmware or hardware on these Pro 5s? I thought it was the former?
Firmware issue as far as I know, although my Pro 5S has never been reliable, compared to my Pro 4 cameras.
There has never been a straight answer as to the scope of the issue.
Seems @BrookeN had stopped replying. I wonder if her management has told her to stop engaging?
It’s a real disgrace and shame how Arlo has gaslighted their customers in failing to properly acknowledge or address the issue.
Mine is sending notifications with no video to show for it. I asked for my account to be closed and was refused. Instead they want a supervisor to call me.
It is pretty poor form for Arlo not to be sufficiently open about issues but as with any big company they would rather dodge questions like politicians so that it hopefully doesn’t affect their sales.
My Pro 4’s were far more reliable despite the audio issue they had (a hardware fault). I thought it would be smooth sailing with the RMA 5S’s as a replacement for them but it has not been. At least the Pro 4’s captured and recorded all events.
@Wolfpretzel I have noticed the same with my pro 4 cameras (garbled audio on recording) - lucky I don't use that too much but it is still really annoying but at least the pro 4 captures ok. The pro 5S miss events and have very jerky capture for the initial phase when they work. They are so disappointing, even more so their pathetic support.
@BrookeN please signal that you are still somewhere out there? You're our only hope!
@chicane are you based in Europe? If so, you can take your Pro 5s back to the seller and ask for a refund on the basis that they're unfit for purpose.
I know you'd rather keep them, but I think this firmware saga and support's attitude in general really sums up the attitude of the whole company to you as a customer. Just a few questions for you to think about:
For starters, why is the product released without being properly tasted? Why is it taking so long to fix the issue? Why is the communication so minimal in terms of what the issues are? Why is there no apology for all that and for the issue itself? Where is the management in all this, given the seriousness of the problem? There's a community manager on here, yet he's hardly visible. Why is there no mention of compensation or goodwill gesture for the problems experienced? Why is there silence recently?
Surely, any reputable company would have been embarrassed by this whole situation and management stepping in to *at least* issue an apology.
Dixit.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
