Arlo Pro 5S - (missing events, taking snapshots). Pro 4 in same location works fine.
Best answers
The firmware has started rolling out. It should be completed within the next week. As soon as that is fully rolled out the behavior you are seeing will be resolved.
I have this escalated to the engineering team. I will update the community as soon as possible.
@roundball Jeff has been in contact with you correct?
05.24.25
@BrookeN and all
Have decided to pause my part-time-arlo-5s-camera-technician-job.
Will store the 5s cams and periodically check for new versions throughout 2025.
I’ve restored my home security system to my excellent Pro4 cams, inside & out.
Thanks to all those who have interacted along the way…
That's terrible that you feel you have to do that.
I'd sell them. Looking into my crystal ball, I can see it's going to be some time before the issues are resolved, if at all.
roundball
Thank you for your service.🖖
Agree I shouldn't have to do that...but I am so tired of the amount of my life being consumed by arlo 5s issues I'm worn out dealing with it.
Aside from the Pro4 audio static noise that arlo claims they can't fix ( so I have audio turned off ) the optical & various adjustments quality of the Pro4 cams are noticeably better than the 5s cams, so my home security system is good and reliable again.
I couldn't in good conscience sell them without clarifying the reason being that I can't rely on them for good protective home security.
If arlo wants to do a cash-back to me, as they should, I'd accept that.
If you're in the EU and the UK, you are thankfully protected by excellent consumer laws. As your agreement is with the seller, you should approach them, not Arlo, unless you bought them directly from them, arguing that these cameras are not fit for purpose. This is because your situation with Arlo Pro 5 constitutes a breach of the sales contract, and you're entitled to seek legal remedies.
Not EU or UK...in the US.
As an aside, the past few days have been as different as night & day with my former Pro4 cam system back in place...4 inside / 4 outside.
Everything works like it always did / like its supposed to.
Recordings are razor sharp, excellent color, and with long range.
So much so, I had to reinstall an activity zone on the driveway cam so it wouldn't keep recording vehicles at the street 105 feet away.
Life is much better again...
I just went threw an hour on the phone trying to get my new pro 5 and my doorbell 2nd gen to send me notifications and we can't get them to. Sometimes the pro 5 worked and sometimes not. The doorbell I was told only now sees at 13' wow that's terrible. New and improved not at all good. Very very saddened by the new cameras.
Understand completely...if you've still got Pro3 or Pro4 cams, my suggestion is go back to them now and don't waste months of your life assuming the 5 is going to become problem-free because it hasn't in a year & a half...track record odds are zero that it ever will.
I agree with @roundball
Support have reached out to me and offered me a refund for my Pro 5S devices (thanks to @BrookeN's involvement).
Is this Arlo conceding they cannot fix the issue? I'm beginning to think so..
Hi @BrookeN - can I please also have a refund? My replacement Pro 5s are missing events. I haven’t been posting about it because, like others, I don’t have the time or energy to keep dealing with these faulty Pro5s, but the performance is still poor, intermittent, and they don’t work as they should.
Either they can't fix them, or they have had enough of this thread. Great result, though. Hope you can purchase something more reliable, Arlo or otherwise.
If they can't fix them, then that means my ultras are probably not going to have better motion detection either.
One of them fails to record moving objects just 2m under its nose 😱
@BrookeN is this refund being offered to all regular participants on this thread still battling with their Pro5 cameras? The replacement I was sent has provided no improvement in performance; I'd be interested to try a Pro4 replacement if that's also an option?
Yes @BrookeN - can you please confirm that a refund will be provided? I’ve located my receipt from 12+ months ago, and can DM it to you. While the replacement Pro 5s are performing somewhat better than my original pro 5s, which never performed properly, they are still missing events, including people walking right under the Pro 5 above my front door. Notifications continue to be laggy and the motion field appears to be incredibly small - animals and people don’t trigger a recording until they’re right under the camera, which is even worse than the original Pro 5s, and certainly worse than the Essential Spotlight cameras I had in the same location. I have no confidence in using the cameras for their intended purpose - as security cameras. They’re advertised by Arlo as security cameras, and they clearly aren’t fit for purpose. I appreciate Arlo sending me the replacement cameras, but they haven’t solved the underlying problem of patchy and unreliable performance.
@BrookeN - I would also be prepared to accept 2 replacement Pro 4 cameras, as an alternative to a refund for the 2 Pro 5s cameras.
I will look into this and let you know as soon as possible.
Yes, please consider me as well...be glad to return my new 5s replacements for Pro4 cams instead.
Throw me into this refund as well. Pro4s would be a good replacement.
The other day one of my Pro5s didnt record or alert on anything right in front of it for an entire day! I could live stream so it was working, then i walk in front of it and nothing. But my doorbell cam caught everything in the same line of sight.
@roundball @BrookeN @chicane @AlixO @GW1a @Edinburgh_lad1 @GeneralMeow @Ocxid
FWIW, it's now been 2 weeks since I put the new replacements pro5s cams back in their new boxes, and settled back down to a good 100% reliable security system of Pro4 cams like it previously was.
The Driveway cam now records any delivery truck & driver pulling into the driveway, then walking down it.
Then picked up by the front porch cam as they walk across the sidewalk and up onto the front porch to leave a package.
Then both cams notify and record them walking away and back up to their truck.
4 separate notifications and recordings by 2 Pro4 cams like they used to.
AND the timing is so immediate that I arrive at the front door as the driver is just going back down the steps.
A very important example this weekend because I was able to notice he'd left the package at the wrong house and was able to tell him while he was still there.
And I suddenly have lots more time to do other things now...
That’s great to know @roundball - thanks for sharing. This is exactly how the Pro 5s should work, but they fall well short. I’m still experiencing delayed notifications and my replacement Pro 5s don’t record anything unless it’s right under the camera (when they’re not missing events). I used to have zones set up on the Essential Spotlights in the same locations because they’d record cars and people going by in the street 5 - 10 meters away. The Pro 5s have never picked up anything that far away.
@BrookeN - I look forward to hearing if a refund for my Pro 5s will be provided, or a replacement of my Pro 5s with Pro 4 cameras, which clearly work well, unlike the Pro 5s.
I am still experiencing significant issues with my video recording cameras, which have failed to capture any footage for periods lasting up to one or two days. Two of the cameras are positioned to monitor a busy suburban street, including my driveway, yet they have recorded no activity. In instances where video is captured, it is inaccurately labeled, and the cameras do not seem to recognize movement from individuals, animals, or other entities. Overall, these cameras have proven to be ineffective. Will there be a resolution for these cameras, or has Arlo ceased its efforts in this regard?
I think i'm going to do the same thing with my Pro5s. I'm done playing around with these things. Just yesterday it missed the FedEx girl coming AND going right under it while she stood there taking a pic of the package for like 2 mins. Then I had to reboot it. I'm going to take them down and move the Pro4s into its place and un-retire my Pro2s to fill the gap.
The Pro4s arent perfect, a little choppy sometimes, but they work MUCH better than the Pro5s.
Refund or replace with Pro4s.
@GeneralMeow I sent you a direct message. Please respond to that.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
