  • 8 Replies
  • 3938 Views
1Scott-
Have the Arlo Pro 5S....Want to add CVR to my cameras.   It does not give me that option.   How can I add CVR to my cameras?   Can I not add it?
8 REPLIES 8
DannyBearAgain
Does the pro5 camera connected to a base/hub?
Not sure if you are asking if it can be, or if it is.
It is compatible with hubs, and if it is connected through a hub and is AC powered then CVR is available.
@1Scott- do you have the pro5s connected to a hub?  Is it powered with AC (not solar)?
1Scott-
Do not have the HUB.  Why do I need it?   Just says better reception to the internet and longer battery life.    How does it help with CVR?   I’m confused.  Argh…..
1Scott-
ahhh CVR is only available with the hub.   What does the hub do?   Is it a hard drive?   Only says better connection to the internet and battery life.
DannyBearAgain
@1Scott- ,
Only arlo knows why you need the hub.
 If I were to guess it provides buffering to the CVR stream during heavy internet traffic.
1Scott-
LOL
Arlo is the only one who knows hahaha but yes buffet for 2k video  is a good guess.
1Scott-
Hey there!
Have the Arlo Pro 5S with VMB5000 hub.   Want to add CVR.  When I try to add a CVR plan no plan is available.  See attached pic.  Thoughts?
DannyBearAgain
Can’t see the attached picture until a arlo moderator vets it.
Can you confirm the pro5 is externally powered with the Ac adapter? Not a solar panel.
