Does the Arlo Pro 5S 2K have a compatible table top mount? It is unclear if this table top mount works with this exact camera model. https://www.arlo.com/en-us/accessories/VMA1100-10000S.html
Table Top Mount
That mount won't work because it's for the older cameras (Pro 2 and older) which have a magnet in the back of the camera. The new cameras have the magnet in the mount itself.
I'd suggest checking Amazon, etc. for camera mounts. Arlo uses the standard 1/4"-20 thread so most mounts would work if you can find one that works for you.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
detection
drained battery
Firmware Update
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
wireless
Zones
