Hello,
Both of my Arlo Pro 5 cameras are showing the same recurring issue, which started immediately after the last firmware update:
Before the update, both cameras worked perfectly even on continuous power.
After the firmware update (current version: 1.060.35.0_26_fe51ebd), when connected to continuous power (with any Arlo official charging cable), after a few hours live view and video recording stop working.
The cameras remain connected (I can still access settings and restart them remotely), but video and motion detection are completely disabled until a manual restart.
When running only on battery, the cameras work perfectly with no issue.
Additional details:
• Model: Arlo Pro 5
• Firmware: 1.060.35.0_26_fe51ebd (issue only appears after this update)
• Camera #1: updated yesterday → issue started immediately after update
• Camera #2: was still on previous firmware and worked fine → updated last night and now shows the exact same issue
• Both cameras were purchased separately and come from different production batches/series
• Connection: tested both via Arlo SmartHub (model 4540) and direct Wi-Fi → same issue in both cases
• Wi-Fi network: stable and strong (Swisscom Internet Box)
• Troubleshooting already attempted: Wi-Fi 2.4 GHz only, IPv6 disabled, DHCP fixed IP, factory reset, reinstallation, SmartHub installation → none resolved the problem
• Tested with different official Arlo chargers and cables:
– Arlo Outdoor Cable 7.6 m
– Arlo Indoor Cable 2.4 m
– Original short charging cable included with the camera
→ The issue occurs with all of them
This clearly confirms that the problem is a firmware bug introduced in the latest version (1.060.35.0_26_fe51ebd) affecting continuous power mode.
Please advise on a solution or provide information on an upcoming firmware fix.
Thanks,
Best answers
I’m actually getting active help from Arlo L3 Support since a week back. We’re testing new FW (f216) and I’m sending them logs after I’ve done certain things, after their instructions. So please be patient. A solution is on the way.
We are continuing to investigate reports of this issue and the development team is working hard to find a solution. While this appears to be isolated to a very small number of users, we're continuing to treat this as a priority investigation. We will share more information as soon as it becomes available and our L3 teams will be in contact with the users here on the community who have reported this issue.
Thank you,
We appreciate everyone’s feedback and patience as we work hard to find a resolution for this issue. We understand the inconvenience this has caused. In the meantime, removing the charging cable serves as a temporary workaround, which some users have already implemented. We’ll be following up with more information and updates on Monday.
yes the set up is all custom done by me i.e record duration, sensetivity, ect, when i spoke to tech sup they didnt know what it was also and said put the internet router in the closest room, even though its currently just 20ft away
Since you can make manual recordings and livestream the camera, it doesn't sound like this is network related to me.
I wouldn't move the router at this point, but you could try measuring your wifi speed at the camera location with your phone. Turn off mobile data, to make sure that you are testing your wifi. The Ookla speedtest app (free) is a good tool for this. Note what matters for recording is the upload speed (and also packet loss). That would let you know definitively whether this is a network problem or not.
On Ookla it was download 53.04 - ping 32ms...on Google it was 44.6 download and 18.8upload
Again, it is the upload speed that matters. ~19 mbps is more than enough (Arlo says you need at least 2). So there is no need to move your router. Which makes sense, since the problem camera is one of your old ones, and it worked before in that location - and you can livestream the camera and make manual recordings.
What I suggest doing next is deleting the rule for this camera in the modes you are using, and then add it back. See if that changes the behavior.
If that doesn't help, then I suggest a hardware reset for the problem camera. Remove it from the account, and then open the housing. Press the button inside until the camera LED flashes amber (~15 sec). Then add the camera back to your account.
just an update. i returned the camera to the store once again and got another brand new one and set up, set all the rules for both arm home and arm away and still wont save any decordings to events, such a strange situation this is and its a real head scratcher
Did you check your feed settings, just to make sure nothing is being filtered out? Those filters are sticky, and it is easy to forget to change them back when you are done with them.
@ShayneS any news from dev team ? They identified the issue when power cable is plugged ?
Looks like the team is still investigating root cause. I will provide more info when I have more to share.
I am experiencing same issue with two 5s cameras on firmware 51ebd
The workaround for now is to just disconnect the AC power.
It’s a shame to sell Camera with this kind of bug !!!
Dev team must update super fast or I will let a really bad comment on TrustedPilot.
Still impossible to make my brand new camera working with AC Power plugged !
@ShayneS same issue when AC Power is connected Arlo Pro 5 2k cameras stop working / not possible to live motion and no detection but camera stay connected, really bad
Yes, but that is clearly not sustainable.
That said, my one 5s now gets distorted periodically (yes it is powered)…I have assumed this is another firmware 51ebd issue…I will restart it remotely which temporarily resumes normal operation…but then it repeats…
with my most recent restart that camera did not connect to WiFi…so I am totally offline until I can get to the camera location - which won’t happen for 2 more months. And the purpose of the camera is to monitor the physical security of the home - which I now cannot do.
I have exactly the same issue with two Pro 5S cameras running firmware 1.060.35.0_26_5e985aa.
Likely a version of that FW for Pro 5/Pro 5s. The team is actively investigating the root cause.
Do you have any timeline for when a fix will be available for the cameras?
Frankly, problems of this magnitude and the long delay in addressing them completely undermine trust in the product, especially given that I’m still paying a monthly subscription for something that doesn’t work properly.
@ShayneS hi, is it possible to have a concrete update ? At least to know if the dev team have identified the issue ?
I’ll continue monitoring this and will update the thread as soon as more information becomes available.
One of my Arlo Pro 5 (H53) has now updated the firmware to 1.060.35.1_43_84676d4. The camera works for livestreams and recordings only as long as it is not 100% charged. After that, i.e. when it is charged and still connected to the power, it unfortunately still does not work despite new firmware. Sorry for my English...
Try rebooting the base - that should trigger the update.
@ShayneS not working. Base Station reboot (VMB4540r4) don't apply the firmware, it stays on 1.060.35.0_26_fe51ebd. I tried to take out the battery of the camera, no firmware update.
Only the cameras connected with direct Wi Fi is updated to 1.060.35.1_43_84676d4.
And the new firwmware don't fix the issue ...
Really disapointing Arlo, thinking to switch to TAPO camera if no solution is provided
I noticed that the Arlo 5S cameras updated their firmware from 1.060.35.0_26_5e985aa to 1.060.35.1_43_84676d4, but the same issue still persists. The cameras can be temporarily fixed by restarting them, but the problem comes back again. In addition, the cameras start working immediately when the power cable is disconnected and they run on battery.
I’m getting frustrated with this issue to the point where I’m already looking into alternative camera manufacturers.
Same for me - firmware updated but the issue persist, after connecting cameras with AC power cable it stop record event and no live possible. Have to reboot the cameras to make them work again or unplug the cable.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
