I have been unable to connect a new Pro 5 camera with my Eero 6 router. I've taken the following steps without success:
- Confirmed that I entered the correct wifi network name and password in the Arlo Secure App during the setup process.
- Temporarily turned off the 5 GHz band on my Eero device and reconnected my iPhone to the network to ensure I'm on the 2.4 GHz band.
- Ensured that my iPhone is not connected to a VPN.
- Ensured that “auto join” settings and Wi-Fi Assist are turned off on my phone.
- Reset my camera to factory settings, confirmed that the camera blue light is blinking, and received the camera chime before attempting to connect.
- Kept both my phone and the camera about 10-15 feet from my router when attempting to connect.
I'm out of options at this point and welcome any ideas or guidance on how to resolve this.
Thanks very much, this was really helpful. I tried all your suggestions above without success, saving for last removing the punctuation (an apostrophe) in the network name. Removing the apostrophe immediately solved the problem but it unfortunately required me to reset all other wi-fi devices in the home to connect to the "new" network. Painful but successful. Given that all other devices in my house recognize punctuation in the network name, it's frustrating that Arlo has that limitation and created a great deal of extra effort for set up.
@Wilbur92 wrote:I'm out of options at this point and welcome any ideas or guidance on how to resolve this.
Try a PC (my.arlo.com) and see onboarding from there works.
I don't own an Eero. Folks who have say that the Eero beacon is a problem, so turn that off if you have one. Others said they needed to disable the Eero "Advanced Security" feature.
Also, make sure the network security is WPA2 (AES). Punctuation in the network name and password can be an issue - unfortunately Arlo has never said what characters get in they way. But if you do use punctuation, then try removing it.
FWIW, I agree. They'd had this particular problem for a long time now, and really should have fixed it by now. Or at least documented the characters that don't work in a knowledge base article.
Generally, there's a lot more friction in onboarding than there should be.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
Wifi connection
wind
Zones
