I have a feed showing all the recordings but somehow .. and for the life of me I cannot find it again ..
I clicked a camera and the feed of all of the videos just on that camera showed up below and I could scroll through them. I am doing this on an iPad.
Anyone figure this out? I did it by accident .. and want to do it on purpose!
Just go to the "Devices" page, and then touch the camera image.
I did that. Nothing.
I can make the image smaller (the arrows in the right top corner) but nothing else. When I make it smaller - above it is a gear and a calendar. … if I try to scroll down, nothing. If I swipe up on the iPad I get the application bar. It has shown up .. and now is gone.
What version of the app are you running?
Also, are you using Android? Or are you using iOS?
Are you still seeing this same behavior?
Morning,
1. I am running an iPad. Lastest version.
2. Running Arlo - updated the app.
When I go to Devices > and see the list of the units - and click on one it brings up the video.
I have attached the photos. I cannot see the “string” of videos on that camera. It came up once and then disappeared.
Photos uploaded - but I cannot see the list of videos, that should “appear” below it.
What if you turn the iPad to landscape mode, does that change the way the view and settings are?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
