AR
  • 2 Replies
  • 1008 Views
Cgwin
I am having hell getting my camera to pop out of the casing so I can charge the battery. I turn the key on the casing, the camera pops out but it won’t come out far enough to remove it. I push it to lock it back in and turn the key again and it still will not pop out far enough. I could probably take a sharp object and force it out but I don’t want to do that until I ask here. Once I get it out any tips on how to get it to pop out easy?
Yes... the O-ring is prob dry and making it stick.
Best answer is to put a small amount of silicon grease on the o-ring
( don't use a petroleum based grease )
Second is to find something else to lube the o-ring...
( in a pinch, I used olive oil which worked for a while , just wipe it down not dripping )
When the camera is out , make sure the inside of shell is clean, wipe out with rag.
Cgwin
Great, thank you so much for your advice! I’m in a pinch, so olive oil to the rescue! Will come back and update when I have to remove them again. Have a wonderful day!
