5S cameras not following modes and automations
  • 7 Replies
  • 508 Views
SierraKP
In the past couple of weeks, I have at least 3 cameras that are not recording according to the modes and automations I have set up. I have not changed anything, and they were previously following my settings. I’ve reset them, removed them from the modes/automations, and still they don’t work correctly. They are the only 3 cameras connected to solar chargers, but other than that, they are the same as the rest of my setup. Any suggestions? I need these to record when I want them to, and not record when they’re supposed to be on standby.
7 REPLIES 7
Did you check the subscription status?
SierraKP
Subscription is fine, nothing changed with it on my end.
Can you post screenshots of the automations?
SierraKP
Yep, but nothing had changed with them, it used to work correctly, then just stopped with zero changes.
It’s east, west, and pasture that aren’t behaving correctly. They will record during the arm home and not during the arm away.
So the issue isn't with the schedule automations, it is with Arm Home mode?
I'm not seeing east, west, and pasture rules in Arm Home - are they still in there?
SierraKP
They aren’t supposed to be active during arm home - that’s why they’re not on the list. They never have been, and prior to about 2 weeks ago, they didn’t record during arm home. Now, randomly, I’ll get a notification and a video from them, even tho they aren’t even part of arm home.
Are you seeing the mode changes in Feed?  That can help you confirm that you are getting recordings when you are in a mode when that shouldn't happen.
