How can I obtain additional wall plates (lost mine) to match to these security mounts? Alternatively, is there a way to mount them on threaded mounts like other Arlo cameras like the 4? As pictured, the hole on the back of the existing mount piece isn't compatible with standard mounts on other types of brackets.
You can't purchase just the wall plates, you'd have to be another complete mount.
Another option is to purchase a new housing that uses a standard mount.
AFAIK, all Arlo threaded holes are 1/4"-20 threads. I could see that a longer bolt on the mount could be needed.
I don't think that is the case with the total security mount. Others have tried to connect the housing to a standard mount, and had no success.
I can validate that it is not threaded. I hoped it was. Alas, I bought new housings with threaded holes. Another option was the ceiling adapter that effectively gave me the wall plate I wanted, but at a 45 degree angle. https://www.arlo.com/en-us/accessories/FBA1001-10000S.html
I doubt these would have worked. They are for the wireless floodlight camera - the mount looks similar to the total security mount you have (had), but isn't exactly the same.
The anti-theft total security mount and Pro 3 floodlight use the same base mount. So the wall plate fits both black and white pro 3 floodlight and VMA5100-10000S Total security mount. If you need just the wall plates, you can find them on google.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
