2 of 10 Arlo Pro 5 cameras not auto detecting motion
  • 28 Replies
  • 7498 Views
GeorgeMerian
Long story short trying to replace 10 Arlo Pro2 Cameras with 10 Arol Pro 5S 2K cameras.   After setting up 10 new Pro 5 cameras with my base station and firmware updated on each cameras,  two of the cameras will not auto-detect motion and record and send me a push notification.
I can turn on each camera live and watch video.  The motion detection test works as the light flickers amber during the test.  I moved motion detection sensitivity to 100% and no luck.
Everything seems to be working except for auto-motion detection.  Any ideas to check?  Another long story but I  am out of phone support warranty on the Pro 5 cameras.
Thanks,
George
Best answers
  • JamesC
    GeorgeMerian,
    I took a look at the subscription plan that you have associated with your account and it appears you have a legacy Arlo Smart Premier plan. This plan supports up to 10 cameras. You have 12 cameras on the account ( 10 Pro 5 and 2 Pro VMC4030), two of the Pro 5 cameras are not associated with the Arlo Smart Premier plan which is likely why you're experiencing an issue.
    I recommend changing your plan to an unlimited Arlo Secure plan to support all of the cameras on your account. For more information on how to change a plan, see here: https://kb.arlo.com/de/1215141/How-do-I-change-or-cancel-my-Arlo-subscription-plan
28 REPLIES 28
@GeorgeMerian wrote:
I thought this was support.
This is a user-to-user forum, and I don't work for Arlo.
Do you know off the top of your head how long is the warranty on these cameras?
This does vary by country, but would be 1 year in the US.  At least that in other countries.
Contact paid support by going into the app (not the browser) and selecting the support area.  Then select a camera in a subscription plan.  Scroll down, and you'll see a phone support option.  They are open from 6 am to 6 pm US pacific time.
GeorgeMerian,
You could also try removing the Pro cameras from the subscription plan.  You'd still get the 7-days of free cloud storage, and you could then move the Pro 5 cameras into the subscription plan.
Still, Arlo Secure is the best path (as Arlo will at some point change your legacy plan over to Secure anyway).
GeorgeMerian
The issue was a screw up on Arlo.  I did try to renew my subscription to Arlo secure and have records I chose that but behind the scenes it actually renewed my old Arlo smart plan.  As a software developer for over 40 years I can attribute this event to **bleep**ty logic in the software Arlo is using to renew subscriptions.
