subscription
I have an account and a subscription that now has 5 older pro cams at my home. I want to setup Arlo at my vacation home with pro4 cameras and a smart hub on the same account. Can I do this? Do I need another subscription for the vacation home? If so how do I put another subscription on the same account? And will the one Arlo app handle both locations?
Yes.
A bit tricky to answer this. The subscription terms of service says yes.
But with the "Library" interface there is no need for two, you just put all the cameras into a single unlimited plan.
The new "Feed" interface is different - normally you'd set up two locations, and each location would need its own subscription plan. It's possible to set up all the cameras as a single "location", though it would be tricky to control the cameras at both homes independently.
You should be able to go into the subscription area of the app, and purchase a second subscription (perhaps a single camera one, if you are only getting one Pro 4).
Yes.
Arlo Pro 4
labels
Samsung SmartThings
