sharing
  • 6 Replies
  • 1722 Views
  • 5 In Conversation
arlouser120924
my person received their email and set up an account with Arlo….. Arlo in return has sent them an email with click on here to confirm your account
They always receive an error message and the account can’t be completed…… Therefore, we cannot share access to the cameras
Also, I cannot reach our customer service for anything and there appears to be no answer on how to set up and correct sharing problems
Can anyone help?
6 REPLIES 6
DannyBearAgain
Try getting the shared account to use a pc to access the email and click on the link to open a browser to proceed with the acceptance.
Using a mobile device invariably fails unfortunately.
bepa85
I sent the shared email and they received. They downloaded the app and created an account. In order for them to view the cameras do they need to following the same steps I used to add them? By doing this it will not remove them from my app, correct? Thanks
NO, you can't do that.  Cameras can only be added to one account.
Instead, they should click on the "create account" link in the email on a PC.  That will open their browser to my.arlo.com.  From there they log into their existing account (including completing the two-factor authentication step).
At that point, you should see the invite as accepted in your account.
There might be one other barrier.  New accounts have "Feed" and "Dashboard" in the app menu (and not "Library").  If your account has "Library" you will need to migrate it to "Feed".  Let us know if you need to do that.
arlouser120924
I wish I understood what that meant
I am actually thinking of taking the cameras down and getting a different brand because I can’t figure out how to make this work
And they have no customer service you are not allowed to talk to anyone unless you pay for it. How ridiculous is that if I knew the customer service was so hideous I would’ve never purchased these cameras in the first place.
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
What is it that you don't understand?
  • 6 Replies
  • 1722 Views
  • 5 In Conversation
