Pro4 flashed amber amber when trying to find network
  • 1 Reply
  • 1035 Views
Taylorzip21
When I'm syncing them I get the blinking blue light, scans the QR code and chimes, then when I go to find the camera it stops blinking blue, flashes amber quickly for about 5 seconds then the light goes dark and it never finds the camera on my network. To try it again I have to reset the camera. But same thing has happened on 3 different cameras.
Verify that your SSID and password for the WiFi don't have special characters (including spaces). You may be able to use your router's guest network to at least test this. You can also try resetting the cameras to see if that helps:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
  • 1 Reply
  • 1036 Views
