							one camera works, can't add a second and third - can't find device
I bought 3 Arlo Pro 4 cameras. The first one could not be found even though i validated everything was what was recommended. ie. 2.4 ghz networks, same network SSID, flashing blue light, etc. Next they recommended i reset to factory settings and repeat the process. I did this and the camera was found immediately. I tried the same for the other 2 cameras and neither of them can be found. has anyone else had this happen to them? if so, ideas to help me fix?
Are you still experiencing this issue with your cameras? Have you tried onboarding via the web portal?
						Arlo Mobile App471
						Arlo Pro 31
						Arlo Pro 42
						Arlo Secure3
						Arlo Smart223
						Arlo Wire-Free1
						Before You Buy345
						Dépannage1
						Features447
						Installation446
						labels1
						Samsung SmartThings1
						Troubleshooting1,827
