iOS app v4.3.6 issue? - Arlo Pro 4 video not appearing in library
I am a long time Arlo user & recently noticed that my Arlo Pro 4 videos are not appearing in my library despite the device page indicating motion. I also note the iOS app was updated 4 days ago to v4.3.6!!! . I have removed & reinstalled the camera & tested it sees motion ok, & restarted my hub (vmb4000r3) to no avail. I currently have no subscription but previously was able to see 5 cameras in the library & now the filter is only showing 3 which are Pro 2 cameras? I note this issue has occurred previously for users due to various software bug. Please advise & fix .. thanks
@EMZ wrote:
I am a long time Arlo user & recently noticed that my Arlo Pro 4 videos are not appearing in my library despite the device page indicating motion. ... previously was able to see 5 cameras in the library & now the filter is only showing 3 which are Pro 2 cameras?
Pro 4 cameras require a subscription for cloud storage - they don't include the 7-day free cloud storage that your Pro 2 cameras do.
Smarthubs (VMB4540 and VMB5000) have a feature called "direct access to local storage" which does allow you to see USB-stored recordings in the app, but NOT the VMB4000. The only way to see those recordings with your base is to eject the USB drive and connect it to a PC.
So the mystery here is how you are were getting recordings before. How long have you had the Pro 4 cameras? There is a short trial subscription, and if these cameras are new, it likely just expired.
The Pro 4 camera I purchased probably not long after it was launched & has always appeared in the library, I have had subscriptions on & off which allowed me to see my 7 cameras but the library always dropped back to 5 when I cancelled. Now I only see 3 of 5..
Can you tell us the models of the cameras that are not saving recordings?
Pro 4 cameras definitely require a subscription to get cloud storage (and always has). you can see that in the list in the "no plan" section here:
Cameras visible or in library marked with a tick or cross
Not sure what would have had the Pro4 showing since I purchased it as I definitely haven’t had a subscription consistently. Has the duration of days held also changed in recent times I thought free used to be 30days ?? Maybe the Pro4 was removed at some point? Either way it is now as good as a brick if you now say it needs a subscription, all my cameras have always shown in library with or without a subscription. Might be time to go in a new direction for my security cameras..
Think I found the answer (link below). Arlo changed their service offering to those who have been long time customers removing free 7 days storage for all the cameras I own & I only just realised! Definitely time to look elsewhere, as sadly the ‘smart’ notifications when on a subscription are often problematic & rarely work as expected..
https://community.arlo.com/t5/Arlo-Smart/Was-the-Free-Smart-Subscription-removed/m-p/1746336
No, that is not correct. They wanted to do that, but the customer feedback convinced them to change their plans. They are now saying that the free 7-day storage will be available for legacy cameras indefinitely.
Your list of firmware isn't helpful - I'm not going to try and track down your camera models from the firmware they are running.
Please provide the actual camera models. You can find this in the app by
- going in to the support area
- selecting the camera
- scrolling down to the product field at the bottom of the page
Alternatively, remove the camera from the housing, take out the battery, and look for a label inside.
Arlo Pro 4
labels
Samsung SmartThings
