Pro4 Offline After Connecting Solar Panel
  • 1 Reply
  • 962 Views
jghughes
Hello,
Hoping to find out why Arlo hub sends reset to Arlo Pro 4 camera after attaching Arlo solar panel to camera, causing camera to go offline, and appreciate any trouble shooting tips and/or advice to help correct/connect
Thanks,
JGH
jghughes,
The symptoms you're describing aren't normal behavior.
Is this an intermittent issue or are you able to reproduce this behavior 100% of the time?
  • 1 Reply
  • 963 Views
