can't discover base unit on wifi or pair with app for pro 4 XL
If you are using the app, try onboarding the base using a PC (browse to my.arlo.com). Ideally connect the PC to your router with ethernet.
Often the PC will successfully onboard when the app fails.
Arlo Pro 4
labels
Samsung SmartThings
