  • 2 Replies
  • 1282 Views
run2bff
I have four cameras with an Arlo Pro wireless system and home base. Can I add a Pro 4 to this system? Will the 4 be compatible with my Pro base station?
Dannybear
Refer to the article below.
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
you will likely need a subscription plan for the pro4 if you want cloud recordings.
Dannybear
Just want to add to @Dannybear's response.
The Pro 4 can also be directly connected to your home wifi, so you could do that (and still use your existing setup).
If you do this, you would need a single-camera Arlo Secure subscription for the Pro 4.
  • 2 Replies
  • 1283 Views
