I am changing my WiFi router. How do I change this on my existing camera? I keep being prompted to do a factory reset and don’t want to go through this set up if there is a way around it?
Thanks in advamce.
Thanks in advamce.
The simplest approach is to configure the new router to use the same network name/password that the old router used.
Arlo Pro 4
labels
Samsung SmartThings
