Wi-Fi be non Wi-Fi hook up
  • 2 Replies
  • 1190 Views
Walximus
I am looking to purchase security cameras. One has direct Wi-Fi connection and the other does not. What is the difference between the two set ups and why would one be more advantageous versus the other?
Dannybear
If you connect a camera that has direct wifi capability to your local router then your recordings are limited to the arlo cloud library.
If the camera is not capable then you need a Base station unit that connects to the camera. Recordings are still sent to the arlo cloud library but a USB device can be used to backup only triggered recordings.(Note: Not all base models can support USB storage and not all of those that do can support viewing access.)
Base stations:
  1. as @Dannybear says provide local storage
  2. are needed for homekit
  3. cameras connected through a base can have somewhat longer battery life.
Direct Connection to WiFi:
  1. can give broader coverage if you have a mesh wifi system
  2. reduces the amount of equipment you need.
  • 2 Replies
  • 1191 Views
