  • 1 Reply
  • 23341 Views
ttwelder
What base station is compatible with pro 4
ShayneS
HI @ttwelder
The Pro 4 camera is compatible with the following Base station/Smart Hubs: VMB4500, 4000, 4540, 5000. You can fond more info here: What is the difference between each Arlo SmartHub and base station?
You can also connect the essential series cameras directly to your router if you like. You can find more info here: How do I connect my Arlo device directly to my WiFi router if the camera is currently connected to a...
  • 1 Reply
  • 23342 Views
