Where to find Arlo Pro XL Battery
Where to find Arlo Pro XL Battery?
Recharging outside is a pain. Using a solar panel to charge the outside Arlo Pro 4 XL bascailly yells "WE HAVE A SECURITY CAMERA!". It's not practical, nor am I able to spend more for a solar charger.
Didn't Arlo believe/think folks would probably want to purchase a spare XL battery (Model No: A-14) and somehow to charge the battery inside? This would allow us to simply swap the freshly charged battery with a low battery.
Going https://www.arlo.com/en-us/accessories/VMA5410-10000S.html and there is no way to purchase the item.
Are the XL batteries no longer supported or made? Did I waste money purchasing my Arlo Pro 4 XL?
More likely a supply-chain challenge, since you can purchase the Pro 4 XL. But they should have the "notifiy me" option on the Arlo site - not sure why that isn't there.
There are a couple in stock at US amazon, and perhaps other resellers.
Arlo Pro 4
labels
Samsung SmartThings
