According to Argo app instructions there is a sync button on the bottom surface of spotlight camera (VMC4050P). But in that location on my camera there is, instead, a magnetic connector for the charging cable and a button to open unit for inserting the removable battery.
Where is the sync button?
You need to open the unit (using the release button) - the sync button is behind it on the bottom of the camera body. This picture is for a different model, but is close enough to help you find it:
Arlo Pro 4
labels
Samsung SmartThings
