Water Ingress
This is an absolute joke of customer service, I bought 3 cameras to protect our property 200 miles away. They worked ok at the start. The batteries wont charge and when taking them down discovered they are all full of water. Can't speak to anyone either. They were all fitted under the eaves of the property
I do not see any cameras on the account. Can you send me a email address associated with the Arlo account? You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Hi there,
Is there any news on the cameras before I cancel the subscription?
Kind regards
Paul McLean
Can you send me a message with a good callback number as well as a good time to call and I will have support reach back out to you.
Hi,
My name is thanks again for your help.
Kind regards
Paul
Thank you for providing that information. I have reached out to support, they will be reaching out as soon as possible.
Arlo Pro 4
labels
Samsung SmartThings
