Wacky views on my arlo pro 4 cameras
- I have 4 Arlo Pro 4 cameras that suddenly stopped (at the same time) displaying the view in which they are pointed at, and instead are showing treetops. Readjusting the cameras did not help. Anyone else experiencing this problem?
If you’re seeing the camera showing it has zoomed to the top left corner then reset the camera position and zoom out using the camera video settings.
Thank you so much. It worked!!!
Arlo Pro 4
labels
Samsung SmartThings
