VMB4500, this unit keeps interrupting my internet feed what is the problem
VMB4500 with 4 cameras, 3 cameras are hard wired in, and the 4th is on a battery. When we have it connected to my modem it will constantly connect and disconnect from the internet then it causes our internet to go out. Help what is the problem?
A couple of possibilities spring to mind:
- The base is too close to the router - try moving it away as far as practical.
- Your internet speeds are low, especially the upload speed. Test by going to speedtest.net to get a new measurement and compare that to what you expect from your ISP.
Is your wifi disconnecting? Or your internet connection?
(The router logs might give you a clue if you don't have a way to connect a device with ethernet).
Arlo Pro 4
labels
Samsung SmartThings
