I purchased an Arlo Pro 4 XL camera kit from Costco and I'm looking for replacement batteries.
Is item "Arlo XL Rechargeable Battery & Housing, SKU: VMA5410-10000S" a replacement battery?
Is it the full size battery: Model A-7a, P/N: 308-50019-03, Min Capacity: 13000mAh?
Or is it the model A-4a (much smaller)?
Will the battery Model A-7a fit in charger VMA5400C even though it is longer than model A-4a?
This model: "VMA5410-10000S" includes a housing. What is this used for? Will it allow me to connect the charging cord to the battery without using the camera?
The housing is used by people who are upgrading a Pro 3/Pro 4/Ultra to XL. It replaces those housings with one that is large enough for the XL battery.
If you already have a Pro 4 XL, you won't need it.
@mef526a wrote:Is it the full size battery: Model A-7a, P/N: 308-50019-03, Min Capacity: 13000mAh?
Yes, it's the 13000 mAH battery.
Yes.
Yes.
Arlo Pro 4
labels
Samsung SmartThings
