Unlock battery
@Mvogt24 wrote:
Lost tool to unlock my Pro4 camera any ideas
I'm guessing you have the security mount.
Not 100% sure, but I think a T9 torx bit will work. Torx sets are quite inexpensive, so you could risk-buy a set.
A 2 mm allen wrench might work in a pinch, though you'd need to angle it, and be careful not to strip the screw.
Arlo Pro 4
labels
Samsung SmartThings
