Unable to login on Android or PC
I have 3 Arlo 4 Pro cameras and a Base station from the time I had the Arlo 2 cameras.
I don't live in the US and in previous attempts to purchase a plan got the reply that it is not possible where I live.
Yesterday I tried to login to the Arlo app on a new Android device.
In the process of doing so, I reset my password.
I was able to re-login on the old Android device but not the new one (no error message).
During the night the cameras were disconnected from the Samsung SmartThings hub (attempt to relink gets a "Country code blocked" error message).
Attempt to login on the web site (to the My Arlo Dashboard) sends me an OTP to my email, when I enter it and tell it to trust the browser I get a "Timed out" error message (I was quick enough and the error isn't correct).
Hi @ChenVaron Are you still experiencing this issue?
Hi @ShayneS ,
Yes, same results (tried now).
@ChenVaron I have provided this info to the support team, they will be reaching out to you as soon as possible.
I have same issue, i csnt connect smarthings neither google home because of this
Arlo Pro 4
labels
Samsung SmartThings
