Total Security Mount
  • 2 Replies
  • 3012 Views
lgbalfa
Can you remove the actual housing from the mount or is it permanent?
It seems that you can only remove the casing inside the housing to change the battery, but what if I want to remove the entire housing from the mount?
Igbalfa,
The housing cannot be removed from the mount. Take a look here for information on the total security mount: How do I use my Arlo Total Security Mount?
lgbalfa
  • 2 Replies
  • 3013 Views
