Solar Panels Not Keeping Batteries Charged
  • 2 Replies
  • 583 Views
viclife
We have three Pro4 cameras at our church. They are mounted higher (which requires a tall ladder) and it’s difficult to replace the batteries. We do use the solar panels but the batteries loose power quickly. I am curious if larger solar panels would help our situation?
There is new panel that is physically a bit larger - but I don't know how its power output compares with the older one.
FWIW, I found that adding an XL battery+housing kit to the camera connected to my panel helped quite a bit, as it takes a lot longer for the battery to discharge.
But I think this depends a lot on how much recording the cameras are doing, and also how well placed the solar panel is.  Mine is not a great spot - attached to the same tree trunk that the camera is connected to.  So there are seasons when it gets quite a bit of shade.
RichWood
I just swapped the small to the large on all my cameras. I'd say about 25% better battery life. They are worth it.
  • 2 Replies
  • 584 Views
