  • 1 Reply
  • 1227 Views
timmmm42
I have installed solar panels for 3 of my cameras. All 3 are getting at least some direct sunlight for parts of the day. Two were working fine and kept the battery pegged at 100% but they are now showing that they are not charging and have begun to drop a little. My 3rd camera is not showing any charging at all. It is very hot right now (around 100 F), but I don't see any limitations on temp for the solar panels.  Any ideas?
Try cleaning the contacts on both the camera and panel cable. WHen reseating the cable, wiggle it as much as you can to try to get the best connection.
  • 1 Reply
  • 1228 Views
