@Bigwaves wrote:
I don't have a subscription to Arlo anymore and use the base station. There is no option to take a snapshot or record video.
You should be able to record video if you attach a flash drive (or microSD card with the VMB5000) to the base - at least 16GB. 128-256GB is a reasonable size. Note you won't be able to make manual recordings or take snapshots while livestreaming - but you will get motion-triggered or audio-triggered recordings.
You can see the videos by ejecting the storage and connecting it to a PC. If you have a VMB4540 or VMB5000 smarthub, you can also access the recordings from the app.
Thanks for the canned response. Again if you want to take a picture while live streaming without an Arlo subscription you can do it with smartthings but not using the Arlo app. A decent workaround.
Arlo Pro 4
labels
Samsung SmartThings
