Smart Hum VMB5000 not accepting any Micro SD card
  • 2 Replies
  • 1442 Views
Retired_Member
Not applicable
I cannot get any of the recommended micro SD cards to work with my VMB5000 Smart Hub.
Any suggestions?
It's possible that you may need to remove the hub and any connected devices from your account and set them back up as if new.
Retired_Member
Not applicable
Bummer.
not the answer I wanted but it makes sense because nothing else has worked.
thank you so much for your reply
  • 2 Replies
  • 1443 Views
