Smart Hum VMB5000 not accepting any Micro SD card
Retired_Member
Not applicable
2023-07-07
10:07 AM
I cannot get any of the recommended micro SD cards to work with my VMB5000 Smart Hub.
Any suggestions?
It's possible that you may need to remove the hub and any connected devices from your account and set them back up as if new.
Retired_Member
Not applicable
2023-07-15
11:20 AM
Bummer.
not the answer I wanted but it makes sense because nothing else has worked.
thank you so much for your reply
Arlo Pro 4
labels
Samsung SmartThings
