Same Modi for multiple Arlo pro 4
Hi,
i have 6 cam Arlo pro 4 without basis station and I cannot group them to set up the same Modi for all. Is it correct ? Is there any way to creat a virtual group, put all the cam in this group and make the Modi for the group ?
it is really annoying to set up for each single camera and each modification has to done again for each one ….
thanks
@Fugu31 wrote:i have 6 cam Arlo pro 4 without basis station and I cannot group them to set up the same Modi for all. Is it correct ?
You're right, there is no way to do this.
There isn't, and I agree it would be much better if there was.
Hi thank you !
do you know if there is any possibility to propose this feature?or is there any list where perhaps it was already proposed and I can push it ?
thank you
regards
Some earlier requests along these lines:
- https://community.arlo.com/t5/Arlo-Idea-Exchange/Arlo-go-grouping-for-multiple-cameras-on-a-schedule...
- https://community.arlo.com/t5/Arlo-Idea-Exchange/Greater-Geofencing-Control-Camera-Grouping-and-Home...
- https://community.arlo.com/t5/Arlo-Idea-Exchange/Ability-to-group-base-stations-to-use-one-mode-rule...
Arlo Pro 4
labels
Samsung SmartThings
