Same Modi for multiple Arlo pro 4
  • 1773 Views
  • 2 Likes
Fugu31
Hi,
i have 6 cam Arlo pro 4 without basis station and I cannot group them to set up the same Modi for all. Is it correct ? Is there any way to creat a virtual group, put all the cam in this group and make the Modi for the group ?
it is really annoying to set up for each single camera and each modification has to done again for each one ….
thanks
You're right, there is no way to do this.
There isn't, and I agree it would be much better if there was.
Fugu31
Hi thank you !
do you know if there is any possibility to propose this feature?or is there any  list where perhaps it was already proposed and I can push it ?
thank you
regards
  • 1773 Views
  • 2 Likes
