Hi. Ive been sent a replacement pro 4 wireless camera....after deleting the old one and adding the new one it now says that this camera is in a trial....I have a subscription! There aren't 3 little lines to the right that I can drag to active subscription....please help...many thanks
You can of course just leave the Pro 4 in the trial subscription for a while.
If you want to move it to your paid subscription now, you need to cancel the trial first. Then you will be able to move it from "no plan" to the paid subscription list.
Arlo Pro 4
labels
Samsung SmartThings
