  • 1 Reply
  • 1974 Views
tgifun
I have two Arlo Pro 4 with the security mounts.  But, I'm missing the flat wall mount plate.  Does anyone know where I can get just that plate?
I can see online that I can buy the whole housing for like $50, but I don't need everything.
I've been trying to design the plate in 3D modeling software to 3D print it, but so far my results are not quite satisfactory.
They don't sell the wall mount separately.  If you have a subscription, you could try Arlo Support - they might offer you a discount.
Though I'd consider getting a traditional housing+mount instead.  IMO the security mount doesn't add much security, and it is unwieldy.
(note that is just the housing.  You can purchase a mount from Arlo, but the threading is standard, so there are lots of third party choices also).
You could maybe try asking support for a discount on the XL upgrade, then you would be getting much longer battery life in return for your purchase.
  • 1 Reply
  • 1975 Views
