I believe I accidentally deleted renewal email that offered continuation of subscription at same price. Can you please resend email
@Arnold250 were you able to find the renewal email. If not can you please send me a dm with a good contact number as well as a good time to reach out and I will have support get a hold of you. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Dunno if this post can get you a new email but the one you deleted should be in your Trash (or similar) unless you empty the trash or immediately delete the message instead of send int to the trash.
Arlo Pro 4
labels
Samsung SmartThings
