Recording locally
My cameras are installed at our lakehouse. I can view live stream but is there a way to set up local recordings so I can view the videos at my home without using a paid subscription? Or do I actually have to be there, at the lakehouse, on the same wifi to view any past recordings? Thanks!
Best answers
First, you need a smarthub (either a VMB4540 or a VMB5000) with at least 16 GB of storage attached.
You can then use the direct access to local storage feature to see recording w/o a subscription. Remote access is possible with most internet service providers - but unfortunately not all of them.
Arlo Pro 4
labels
Samsung SmartThings
