We just purchased new Arlo Pro 4 cameras. We are currently using older model cameras with a base station (no subscription required). When setting up my new cameras, can I add them AND the subscription to my existing account or do I need a separate account?
Yes. The latest subscriptions include all cameras (unlimited) automatically and enhance what you used to get with the free 7 day plan (30 days cloud recording, etc.).
You can add them to the existing account. If the base is compatible (VMB4xxx), you could connect the Pro 4s through the existing base. Or instead connect them to your home wifi.
You should get the trial subscription for each Pro 4 as you install it. Wait until the subscription expires before purchasing one. Arlo Secure has unlimited cameras, so it would include the legacy cameras (which you can continue to use).
Arlo Pro 4
labels
Samsung SmartThings
